[Solved] SD.h or SDfat.h with SPI2
jenspogo
Post by jenspogo »
Hey guys :)
I'm trying to use the SD.h or the SDfat.h lib with the second SPI on an STM32F103 - but I'm failing.
My Idea was to remap the Pins:
#include <SPI.h>
while(!Serial)
SPI.setMISO(PB14);
SPI.setMOSI(PB15);
SPI.setSCLK(PB13);
SPI.setSSEL(PB12);
Serial.print("MISO is: ");
Serial.print(MISO);
Serial.print(" but should be: ");
Serial.println(PB14);
Serial.print("MOSI is: ");
Serial.print(MOSI);
Serial.println(PB15);
Serial.print("SCK is: ");
Serial.print(SCK);
Serial.println(PB13);
Serial.print("CSS is: ");
Serial.print(SS);
Serial.println(PB12);
But it seems, not to work:
MISO is: 26 but should be: 14
MOSI is: 27 but should be: 13
SCK is: 25 but should be: 15
CSS is: 24 but should be: 16
Or is there another way to do what I want?
Greetings, Jens
Answers: 109
Re: SD.h or SDfat.h with SPI2
Well, this is normal you got this as the SCK, MOSI and other are a define. using the SPI.setxxx will not change those define.
But the setxxx will change the used one for the SPI instance...
jenspogo
Post by jenspogo »
oh :D
It works.
my fault ;)
FerroFerido
Post by FerroFerido »
fpiSTM wrote: Wed Jun 10, 2020 8:56 am Well, this is normal you got this as the SCK, MOSI and other are a define. using the SPI.setxxx will not change those define.
I want save datas in a SD Card, You have any exemplos for help me? Please, i really need there. (I'm sorry my horrible english, i'm lerning now)
mlundin
Re: [Solved] SD.h or SDfat.h with SPI2
Post by mlundin »
@FerroFerido There is a SD library https://github.com/stm32duino/STM32SD. The library can be installed from the Arduino library manager. There are example projects distributed with the library.
Nobody can give more help without information about what board you have, the SD card reader and the type and amount of data you have to save.
Answers: 109
STM32SD library is for SD card slot connected to SDIO or SDMMC IP of the MCU.
If you use an SPI SD card slot then simply use the Arduino SD library.
For both several example are provided.
FerroFerido
mlundin wrote: Wed Nov 18, 2020 10:15 am @FerroFerido There is a SD library https://github.com/stm32duino/STM32SD. The library can be installed from the Arduino library manager. There are example projects distributed with the library.
The Module who i'm using has a SPI conecction and my board is a Bluepill.
FerroFerido
fpiSTM wrote: Wed Nov 18, 2020 10:45 am STM32SD library is for SD card slot connected to SDIO or SDMMC IP of the MCU.
my doubt about this case is: my board it's a BluePIll, it has more than two SPIO pins, who i can use this library in this case? Does It the same thing?
FerroFerido
FerroFerido wrote: Wed Nov 18, 2020 2:20 pm
I want save temperature in TXT format. Its possible?
Answers: 109
Please refers to:
https://www.arduino.cc/en/reference/SD
Note SPIO does not exists AFAIK. F103 does not have SDIO/SDMMC IP so forgot this.
