HID Upload Error Arduino
Bootloader for STM32F103 and STM32F4xx micro-controllers
No special driver is required. Support for Windows, Linux and Mac Operating System
Matt303
Post by Matt303 »
I'm getting the error described below which does not indicate much info, here is the video guide I followed. I have tried this on 5 different blue pills, some of which are 128k they are all different models from different batches/suppliers. I uploaded the stm32 binaries via st-link 32.
https://www.youtube.com/watch?v=Myon8H111PQ
Sketch uses 27032 bytes (41%) of program storage space. Maximum is 65536 bytes.
Global variables use 3844 bytes (18%) of dynamic memory, leaving 16636 bytes for local variables. Maximum is 20480 bytes.
|         HID-Flash v2.2.1 - STM32 HID Bootloader Flash Tool            |
|     (c)      2018 - Bruno Freitas       http://www.brunofreitas.com   |
|     (c) 2018-2019 - Vassilis Serasidis  https://www.serasidis.gr      |
|   Customized for STM32duino ecosystem   https://www.stm32duino.com    |
An error occurred while uploading the sketch
Usage: hid-flash <bin_firmware_file> <comport> <delay (optional)>
Answers: 25
Re: HID Upload Error Arduino
Which core you used ?
Anyway some issues have already been submitted on the HID Bootloader:
https://github.com/Serasidis/STM32_HID_ ... der/issues
Matt303
Post by Matt303 »
I'm using the official stm32 core v1.9.0 I have already been through all those but nothing there to help me with my problem. Am I best to comment there rather than on here? I'm using Arduino 1.8.12 with windows 10. After flashing the low-medium density binaries for pc-13 the blue pill will show up as HID compliant vendor-defined device in the device manager. I have tried a full chip erase as suggested elsewhere without any luck. I don't think it's an issue with the blue pills but the HID upload process which does not indicate what the error was. Do you think this is a bug issue and should be posted as an issue on GitHub?
Edit:
I have gone back and tried v1.8.0 core with the exact same results. Could this be a possible driver issue with windows? Is there a way to debug the HID-Flash tool? I did notice some warnings if they are related or not. Same warnings with v1.8.0 and v1.9.0
In file included from C:\Users\Matthew\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_tim_ex.c:5:
C:\Users\Matthew\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim_ex.c: In function 'HAL_TIMEx_RemapConfig':
C:\Users\Matthew\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim_ex.c:1734:60: warning: unused parameter 'htim' [-Wunused-parameter]
 1734 | HAL_StatusTypeDef HAL_TIMEx_RemapConfig(TIM_HandleTypeDef *htim, uint32_t Remap)
"C:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\tools\\xpack-arm-none-eabi-gcc\\9.2.1-1.1/bin/arm-none-eabi-gcc" -mcpu=cortex-m3 -mthumb "@C:\\Users\\Matthew\\AppData\\Local\\Temp\\arduino_build_538584/sketch/build_opt.h" -c -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD "-IE:\\Documents\\Arduino\\BP_pwm_out" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/avr" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/stm32" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/stm32/LL" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/stm32/usb" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/stm32/OpenAMP" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/stm32/usb/hid" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino/stm32/usb/cdc" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Drivers/STM32F1xx_HAL_Driver/Inc" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Drivers/STM32F1xx_HAL_Driver/Src" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/STM32F1xx" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Middlewares/ST/STM32_USB_Device_Library/Core/Src" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Middlewares/OpenAMP" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Middlewares/OpenAMP/open-amp/lib/include" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Middlewares/OpenAMP/libmetal/lib/include" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Middlewares/OpenAMP/virtual_driver" -DSTM32F1xx -DARDUINO=10812 -DARDUINO_BLUEPILL_F103C8 -DARDUINO_ARCH_STM32 "-DBOARD_NAME=\"BLUEPILL_F103C8\"" -DSTM32F103xB -DUSBCON -DUSBD_VID=0 -DUSBD_PID=0 -DHAL_PCD_MODULE_ENABLED -DUSBD_USE_CDC -DHAL_UART_MODULE_ENABLED -DBL_HID -DVECT_TAB_OFFSET=0x800 "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\tools\\CMSIS\\5.5.1/CMSIS/Core/Include/" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Drivers/CMSIS/Device/ST/STM32F1xx/Include/" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\system/Drivers/CMSIS/Device/ST/STM32F1xx/Source/Templates/gcc/" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\tools\\CMSIS\\5.5.1/CMSIS/DSP/Include" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\cores\\arduino" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\variants\\PILL_F103XX" "-IC:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\libraries\\SrcWrapper\\src" "C:\\Users\\Matthew\\AppData\\Local\\Arduino15\\packages\\STM32\\hardware\\stm32\\1.9.0\\libraries\\SrcWrapper\\src\\HAL\\stm32yyxx_hal_wwdg.c" -o "C:\\Users\\Matthew\\AppData\\Local\\Temp\\arduino_build_538584\\libraries\\SrcWrapper\\HAL\\stm32yyxx_hal_wwdg.c.o"
C:\Users\Matthew\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim_ex.c:1734:75: warning: unused parameter 'Remap' [-Wunused-parameter]
I gave up on the HID upload and just did the upload via the STM cube swd option using st link v2 and have serial enabled for future uploads via com port. Even this does not work and it shows up correctly in the device manager and I have the correct com port selected. This all used to work fine months ago when I programmed up 5+ blue pills for other projects. Now nothing works. I'm wondering if it's linked to Arduino massive shut down yesterday that stopped the IDE from working and everyone had to delete package-index.json files and cache and reinstall Arduino. Even the serial port is working and getting data back on serial monitor so something strange going on with the HID-Flash. Whether this is because I have bypassed the HID upload method first and did it via the cube swd and switched back to HID and this is not compatible?
C:\Users\Matthew\AppData\Local\Arduino15\packages\STM32\tools\STM32Tools\1.4.0/tools/win/hid-flash.exe C:\Users\Matthew\AppData\Local\Temp\arduino_build_538584/BP_pwm_out.ino.bin COM5
> Trying to open the [COM5]...
> Toggling DTR...
> Searching for [1209:BEBA] device...
Error - [1209:BEBA] device is not found :(> Searching for [COM5] ...
> [COM5] is found !
> Finish
the selected serial port > Finish
 does not exist or your board is not connected
Return to “STM32 HID bootloader”
