Sparkfun LTE Shield troubles
Max44
Post by Max44 »
I'm planning to use the Sparkfun LTE Shield on a Nucleo 64 board (Nucleo F401RE). I've installed the Sparkfun library and I am attempting to compile their SMS_Send example. This compiles fine for an Arduino Uno. When I try to compile for the Nucleo board, I'm getting an undefined reference during the linker stage. The Sparkfun library .cpp file seemed to compile OK and an object file was created. See code snippets below. I suspect the pointer to the SoftwareSerial definition is the problem, but I don't know how to work around it. I'm hoping someone might have some similar experience and can provide guidance or can tell me if this is a problem with SoftwareSerial.
Thanks, Max
This is the error message:
01_SMS_Send.ino.cpp:(.text.setup+0x16): undefined reference to `LTE_Shield::begin(SoftwareSerial&, unsigned long)'
collect2.exe: error: ld returned 1 exit status
Using library SparkFun_LTE_Shield_Arduino_Library at version 1.2.0 in folder: E:\Affinity\Water Device\libraries\SparkFun_LTE_Shield_Arduino_Library
Using library SoftwareSerial at version 1.0 in folder: E:\Documents\ArduinoData\packages\STM32\hardware\stm32\1.9.0\libraries\SoftwareSerial
Using library SrcWrapper at version 1.0.1 in folder: E:\Documents\ArduinoData\packages\STM32\hardware\stm32\1.9.0\libraries\SrcWrapper
exit status 1
Error compiling for board Nucleo-64.
The relevant sample sketch section:
#define LTE_SHIELD_SOFTWARE_SERIAL_ENABLED
//Click here to get the library: http://librarymanager/All#SparkFun_LTE_Shield_Arduino_Library
#include <SparkFun_LTE_Shield_Arduino_Library.h>
// Create a SoftwareSerial object to pass to the LTE_Shield library
SoftwareSerial lteSerial(8, 9);
// Create a LTE_Shield object to use throughout the sketch
LTE_Shield lte;
// Set the cell phone number to be texted
String DESTINATION_NUMBER = "11234567890";
  if ( lte.begin(lteSerial, 9600) ) {
    Serial.println(F("LTE Shield connected!"));
  Serial.println(F("Type a message. Send a Newline (\\n) to send it..."));
And the definition of the begin function in the library .cpp file:
#ifdef LTE_SHIELD_SOFTWARE_SERIAL_ENABLED
boolean LTE_Shield::begin(SoftwareSerial &softSerial, unsigned long baud)
    LTE_Shield_error_t err;
    _softSerial = &softSerial;
    err = init(baud);
    if (err == LTE_SHIELD_ERROR_SUCCESS)
        return true;
    return false;
by fpiSTM » Thu Jun 18, 2020 8:14 am
Hi @Max44
Max44 wrote: Wed Jun 17, 2020 7:16 pm Yes, LTE_SHIELD_SOFTWARE_SERIAL_ENABLED was defined. I added that to make sure as seen 1st line in 2nd code snippet.
No it is not properly defined. As it is only defined in the sketch but when the library build then it is not defined.
I've made a PR to add the STM32 core support.
https://github.com/sparkfun/SparkFun_LT ... ary/pull/9
If you can test and give your feedback.
Thanks in advance.
Re: Sparkfun LTE Shield troubles
Is LTE_SHIELD_SOFTWARE_SERIAL_ENABLED defined?
Probably the lib does not handle this core and need some additions. If the lib handle a HardwareSerial, I advise to use it.
Ex: https://github.com/sparkfun/SparkFun_LT ... y/issues/6
Max44
Post by Max44 »
Thanks for the reply.
Thanks for the link. I will give HardwareSerial a try. The problem there is I will have to jumper into the shield versus plugging it into the Arduino connectors as pins 8 and 9 on the shield do not match the hardware USART pin assignments. That's OK with me to do this if the code compiles.
I want to use a STM32 as the MCU driving a ublox SARA-R4 module and was hoping the Sparkfun library would save some work. If HardwareSerial doesn't build, I'll head back over to STM32CubeIDE.
Max
Max44
Post by Max44 »
Following the HardwareSerial example on the Wiki, I commented out SoftwareSerial and added:
HardwareSerial Serial1(PA10, PA9);
And changed lteSerial to:
  if ( lte.begin(Serial1, 9600) ) {
This compiles!
I don't have the LTE Shield in yet, so we'll see if the code loads and runs later.
Cheers! Max
Hi @Max44
Thanks in advance.
