Can't get serial to work
Bacab
Post by Bacab »
Hi everyone,
I feel very dumb for having such a basic issue yet I could not find a solution and I resorted to ask. I can't get my board to print anything on the serial terminal of the Arduino IDE. As far as I can tell everything is setup correctly : I can upload a blinking led code to the board and have it blinked its led, yet for some reason I can't get the serial.print command to work. No error during compilation or upload, there is just nothing printed.
The code I'm trying is the following :
    pinMode(D13, OUTPUT);
  Serial.println("Coucou");
  digitalWrite(D13, HIGH);
  delay(500);
  digitalWrite(D13, LOW);
  delay(500);
The code does not hang on the serial.print, it goes on and the led blinks.
I'm using the Arduino IDE (1.8.13) to program a Nucleo 64 STM32L053R8 on a windows 8.1 computer. I'm using the the STM32Core in its 1.9.0 version.
I'm using those settings :
card type : nucleo 64
board part number : Nucleo L053R8
USART support : enabled (generic serial)
USB support : CDC (generic serial supersede USART)
USB speed : Low/full
Optimize : smallest (OS default)
C runtime library : "Newlib nano (default)"
Upload method : mass storage
Thank you in advance for your help.
Re: Can't get serial to work
There is no CDC on this board. Remove the usb cdc option. This is a Real uart connected to the stlink which provide a CDC.
Bacab
Post by Bacab »
Thank you for you answer.
I removed the CDC option, switched to "nothing", re-compile however the issue remains.
ejdereldek
Post by ejdereldek »
It is an old topic but exact same issue here. on nucleo 144 and nucleo 32 boards i cant get anyting on screen when i use arduino ide. I already follow above recommendations but no luck. any help highly appreciated.
ejdereldek wrote: Thu Nov 18, 2021 4:39 pm It is an old topic but exact same issue here. on nucleo 144 and nucleo 32 boards i cant get anyting on screen when i use arduino ide. I already follow above recommendations but no luck. any help highly appreciated.
Hard to help with those information.
Could you be more precise? Board, option, core version,...?
hobbya
Post by hobbya »
By default Nucleo 64 STM32L053R8 has Serial2 connected to on-board STLink.
So you need to change your code from Serial to Serial2 and connect your PC to the STLink USB port.
If you want to use Serial1 you need to add below and connect the port to PC via a USB-Serial converter:
HardwareSerial Serial1(PA10, PA9);
hobbya wrote: Fri Nov 19, 2021 3:50 am By default Nucleo 64 STM32L053R8 has Serial2 connected to on-board STLink.
@hobbya yes the STlink is connected to Serial2 so Serial is mapped on it.
No need to change Serial to Serial2 as it is the same instance.
ejdereldek
fpiSTM wrote: Thu Nov 18, 2021 5:32 pm
nucleo 144 - f767ZI
nucleo 32 - g431kb
i found the solution in another topic. After Serial.begin(); just add while (!Serial); it worked for me. thanks for support.
while(!Serial); is useful for USB CDC.
