Help understanding boards.txt (adding new board)
gentijo
Post by gentijo »
Hi, I am a bit confused on how new boards work, I am coming from the perspective on understanding how the existing
BlackPill 411CE works.
After loading V1.9 of the board support package, I get entries for the Generic 411CE and the BlackPill 411.
If I select BlackPill 411 and compile / load the Blink example it works.
If I select Generic 411CE it will compile and load, but it won't run or it may be running but the LED does not blink.
I wanted to see how the two boards were supported and what was different, I was expecting a different pin mapping.
In the variant directory, there is no entry for the BlackPill F411CE, there are other BlackPill entries but not the 411
In boards.txt, I find the BlackPill entry (below) but it looks as if it's an alias entry for the Generic 411CE entry since the
product_line and build_variant entries are identical.
I went to the Github entry to look at the code there and it appears to be the boot code for a micro python environment.
Can someone explain how this works ?
Thank you
-John
# BlackPill F411CE
# https://github.com/mcauser/WEACT_F411CEU6
GenF4.menu.pnum.BLACKPILL_F411CE=BlackPill F411CE
GenF4.menu.pnum.BLACKPILL_F411CE.upload.maximum_size=524288
GenF4.menu.pnum.BLACKPILL_F411CE.upload.maximum_data_size=131072
GenF4.menu.pnum.BLACKPILL_F411CE.build.board=BLACKPILL_F411CE
GenF4.menu.pnum.BLACKPILL_F411CE.build.product_line=STM32F411xE
GenF4.menu.pnum.BLACKPILL_F411CE.build.variant=Generic_F411Cx
# Generic F411CE
GenF4.menu.pnum.Generic_F411CE=Generic F411CE
GenF4.menu.pnum.Generic_F411CE.upload.maximum_size=524288
GenF4.menu.pnum.Generic_F411CE.upload.maximum_data_size=131072
GenF4.menu.pnum.Generic_F411CE.build.board=GENERIC_F411CE
GenF4.menu.pnum.Generic_F411CE.build.product_line=STM32F411xE
GenF4.menu.pnum.Generic_F411CE.build.variant=Generic_F411Cx
Re: Help understanding boards.txt (adding new board)
in fact this is the same variant as it is the same mcu.
The only difference is that the board name definition is used to perform some change:
https://github.com/stm32duino/Arduino_C ... .h#L74-L87
// On-board LED pin number
#ifdef ARDUINO_BLACKPILL_F411CE
#define LED_BUILTIN             PC13
#elif !defined(LED_BUILTIN)
#define LED_BUILTIN             PA5
#define LED_GREEN               LED_BUILTIN
// On-board user button
#define USER_BTN                PA0
#elif !defined(USER_BTN)
#define USER_BTN                PC13
As you can see for the Blackpill the LED_BUILTIN and the USER_BTN are defined differently.
Moreover the HSE value is not the same:
#define HSE_VALUE               25000000U
That's explain why the generic doesn't work. Anyway it is possible to use the generic by redefining the HSE_VALUE and using the correct pin for the LED.
gentijo
Post by gentijo »
Thank you, that was very helpful
