Help understanding boards.txt (adding new board)
Posted: Fri Jul 03, 2020 6:40 am
Hi, I am a bit confused on how new boards work, I am coming from the perspective on understanding how the existing
BlackPill 411CE works.
After loading V1.9 of the board support package, I get entries for the Generic 411CE and the BlackPill 411.
If I select BlackPill 411 and compile / load the Blink example it works.
If I select Generic 411CE it will compile and load, but it won't run or it may be running but the LED does not blink.
I wanted to see how the two boards were supported and what was different, I was expecting a different pin mapping.
In the variant directory, there is no entry for the BlackPill F411CE, there are other BlackPill entries but not the 411
In boards.txt, I find the BlackPill entry (below) but it looks as if it's an alias entry for the Generic 411CE entry since the
product_line and build_variant entries are identical.
I went to the Github entry to look at the code there and it appears to be the boot code for a micro python environment.
Can someone explain how this works ?
Thank you
-John
# BlackPill F411CE
# https://github.com/mcauser/WEACT_F411CEU6
GenF4.menu.pnum.BLACKPILL_F411CE=BlackPill F411CE
GenF4.menu.pnum.BLACKPILL_F411CE.upload.maximum_size=524288
GenF4.menu.pnum.BLACKPILL_F411CE.upload.maximum_data_size=131072
GenF4.menu.pnum.BLACKPILL_F411CE.build.board=BLACKPILL_F411CE
GenF4.menu.pnum.BLACKPILL_F411CE.build.product_line=STM32F411xE
GenF4.menu.pnum.BLACKPILL_F411CE.build.variant=Generic_F411Cx
# Generic F411CE
GenF4.menu.pnum.Generic_F411CE=Generic F411CE
GenF4.menu.pnum.Generic_F411CE.upload.maximum_size=524288
GenF4.menu.pnum.Generic_F411CE.upload.maximum_data_size=131072
GenF4.menu.pnum.Generic_F411CE.build.board=GENERIC_F411CE
GenF4.menu.pnum.Generic_F411CE.build.product_line=STM32F411xE
GenF4.menu.pnum.Generic_F411CE.build.variant=Generic_F411Cx
Thank you
-John
# BlackPill F411CE
# Generic F411CE
