Code crashing? PC 13 flashing with wire lib
georgesshed
Post by georgesshed »
Hi all,
Im trying to use an mpu6050 with the stm32 duino.
It seems to for but after a random amount of time (5-15 seconds) the serial output stops and PC13 led starts flashing?
i cant find reference to this issue sanywhere and dont know what is wrong as it works for a bit?
#include<Wire.h>
const int MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
void setup(){
Wire.begin();
//Wire.setClock(400000);
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
int xAng = map(AcX,minVal,maxVal,-90,90);
int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print("AngleX= ");
Serial.println(x);
//Serial.print("  AngleY= ");
//Serial.println(y);
//Serial.print("AngleZ= ");
//Serial.println(z);
//Serial.println("-----------------------------------------");
delay(100);
Answers: 109
Re: Code crashing? PC 13 flashing with wire lib
You request 14 bytes and read only 6 ?
You said the LED is blinking?
ON which board? it seems strange as no handler use the LED by default and your code doesn't seem to mange the LED.
dingexamine
Post by dingexamine »
It seems to function well, however after some arbitrary period of time (between 5 and 15 seconds), the serial output ceases and the PC13 led begins blinking. As it seems to function for a while, but then stops, I can't seem to locate any mention of this problem anywhere.
