Hola
DSSP
Hola
Post by DSSP »
Hi, normally I only tend to read the forums when I have a problem, but right now I am trying to do a monitoring system and I have a problem where I cannot use DHT.h from adafruit and do a reading of the ADC, and I wanted to see if someone can help me to se what I am doing wrong.
pdt i use google translate, so sorry if my english is bad .
Re: Hola
Help us out a bit with some background:
- Your specific board / uC
- Which core?
- Specific link to Adafruit DHT version (over time several now retired versions)
- Compiler error message(s) ?
The most recent Adafruit lib for DHT is:
https://github.com/adafruit/DHT-sensor-library
And you may wish to read regarding dependencies: https://github.com/adafruit/DHT-sensor- ... /issues/62
Author got this to work:
https://how2electronics.com/humidity-te ... ontroller/
Re: Hola
i did something here with DHT22 on libmaple core
viewtopic.php?f=7&t=530
no libraries, but Adafruit's library is a good starting point and it may just work with the official core
