SerialUSB doesn't work on Maple Mini and Bootloader2.0
Ralf9
Re: SerialUSB doesn't work on Maple Mini
Post by Ralf9 »
Which value of USBD_ENUM_DELAY should I test?
I have testet 100 and 500
So if this not works then this is probably an other issue.
Anyway, as said I could not reproduce so hard to help on this.
Ralf9
Post by Ralf9 »
I have tested with another maple mini and other bootloader and find out:
With the orginal bootloader
http://docs.leaflabs.com/static.leaflab ... i_boot.bin
the serialUSB works too after a reset or plug off
With the bootloader20
https://github.com/rogerclarkmelbourne/ ... tm32f1.ino
or this
https://github.com/rogerclarkmelbourne/ ... boot20.bin
the serialUSB works not after a reset or plug off.
With "# ls -l /dev/serial/by-id" no usb device is displayed
BennehBoy
Post by BennehBoy »
And you've loaded a sketch with serialusb enabled after reflashing with each bootloader? Roger's bootloader will stay in DFU mode if there's not sketch resident.
Ralf9
Post by Ralf9 »
I loaded this test sketch after reflashing with each bootloader
int8_t led = 0;
   pinMode(LED_BUILTIN, OUTPUT);
  if(Serial.available()) {
    char c = Serial.read();
    Serial.print("hello ");
    Serial.print(c);
    Serial.println();
  led = ~ led & 1;
  digitalWrite(LED_BUILTIN, led);
  delay(100);
BennehBoy
Post by BennehBoy »
And you have USART support set to enabled 'generic serial'
And USB Support set to "CDC generic 'serial' supercede USART"
Ralf9
Post by Ralf9 »
Right after the upload of the testsketch is the usb device available and the serialUsb works
insgesamt 0
lrwxrwxrwx 1 root root 13 16. Feb 19:53 usb-STMicroelectronics_MAPLEMINI_F103CB_CDC_in_FS_Mode_8D82067E4850-if00 -> ../../ttyACM0
after a reset or plug off, with "# ls -l /dev/serial/by-id" no usb device is displayed
and the serialUSB do not works
I use the core 1.8.0
see Attachments:
Bakisha
Post by Bakisha »
Try with
Serial.begin(115200); while (!Serial) {    yield();  }
in setup.
I had few troubles also with usb serial on stm32duino core, and that line fixed that. Annoying part is only that sketch won't continue untill there is working serial communication with PC.
Also, for me, when board is unplugged, i had to close serial monitor and open it again after i plug in board to be able to have serial.
Ralf9
Re: SerialUSB doesn't work on Maple Mini and Bootloader 2.0
Post by Ralf9 »
Try with ... in setup.
it doesn't work with that either
without a working serialUsb, I cannot use the bootloader20
With the orginal bootloader the serialUsb works also after a reset.
Ralf9
Post by Ralf9 »
I found out that I can with "dmesg -w -e" also test whether the SerialUSB works.
I use this test sketch
int8_t led = 0;
//#define USBD_ENUM_DELAY 500
  led = ~ led & 1;
  delay(200);
I flash with this:
./dfu-util -d 1eaf:0003 -a 1 -D /tmp/arduino_build_70869/MapleminiTestusb.ino.bin -R
With the orginal bootloader it works too after reset or plug in:
[  +7,407971] usb 3-9: new full-speed USB device number 11 using xhci_hcd
[Apr13 00:37] usb 3-9: New USB device found, idVendor=1eaf, idProduct=0003
[  +0,000001] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0,000001] usb 3-9: Product: Maple 003
[  +0,000001] usb 3-9: Manufacturer: LeafLabs
[  +0,000001] usb 3-9: SerialNumber: LLM 003
[  +2,451835] usb 3-9: USB disconnect, device number 11
[  +0,306822] usb 3-9: new full-speed USB device number 12 using xhci_hcd
[  +0,149432] usb 3-9: New USB device found, idVendor=0483, idProduct=5740
[  +0,000002] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0,000000] usb 3-9: Product: MAPLEMINI_F103CB CDC in FS Mode
[  +0,000001] usb 3-9: Manufacturer: STMicroelectronics
[  +0,000001] usb 3-9: SerialNumber: 6D8824785548
[  +0,000460] cdc_acm 3-9:1.0: ttyACM0: USB ACM device
With the bootloader2.0 there is no "ttyACM0" after reset
## press reset button
[ +20,228840] usb 1-9: USB disconnect, device number 60
[  +0,470319] usb 1-9: new full-speed USB device number 61 using xhci_hcd
[  +0,149091] usb 1-9: New USB device found, idVendor=1eaf, idProduct=0003
[  +0,000001] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0,000001] usb 1-9: Product: Maple 003
[  +0,000001] usb 1-9: Manufacturer: LeafLabs
[  +0,000005] usb 1-9: SerialNumber: LLM 003
## flash
[  +1,507190] usb 1-9: reset full-speed USB device number 61 using xhci_hcd
[  +0,147934] usb 1-9: device firmware changed
[  +0,000081] usb 1-9: USB disconnect, device number 61
[  +0,127730] usb 1-9: new full-speed USB device number 62 using xhci_hcd
[  +0,149344] usb 1-9: New USB device found, idVendor=0483, idProduct=5740
[  +0,000002] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0,000001] usb 1-9: Product: MAPLEMINI_F103CB CDC in FS Mode
[  +0,000000] usb 1-9: Manufacturer: STMicroelectronics
[  +0,000001] usb 1-9: SerialNumber: 8D7452895051
[  +0,000449] cdc_acm 1-9:1.0: ttyACM0: USB ACM device
[  +6,039450] usb 1-9: USB disconnect, device number 62
[  +0,000065] cdc_acm 1-9:1.0: failed to set dtr/rts
[  +0,414680] usb 1-9: new full-speed USB device number 63 using xhci_hcd
[  +0,149008] usb 1-9: New USB device found, idVendor=1eaf, idProduct=0003
[  +0,000000] usb 1-9: Manufacturer: LeafLabs
[  +0,000001] usb 1-9: SerialNumber: LLM 003
I also tested it with
