STM32F411VE HardwareSerial sends garbage
meold
Post by meold »
Hi, I'm trying to migrate from 1.9.0 to 2.4.0 arduino core and have an issue with usart.
Initialization:
#define TX_PIN                                PA15
#define RX_PIN                                PB3
HardwareSerial hws(RX_PIN, TX_PIN);
const char data[] = {0xAA, 0x00, 0xFF};
  hws.begin(19200, SERIAL_8N1);
Loop:
  hws.write(data, 3);
As a result I'm getting garbage:
All the possible actions like speed, mode, pinout and other already checked. In the variant all is correctly configured. Same code correctly works on 1.9.0 core.
It is strange, that received bytes count is not equals to bytes sent.
by fpiSTM » Wed Feb 22, 2023 4:24 pm
OK. That's fine if you declare it.
Pay attention for USB, it requires 48MHz input clock.
I saw that you used HSE. My guess is that the value of this HSE is not the default one defined by STM32 HAL:
https://github.com/stm32duino/Arduino_C ... h#L99-L101
which is 8MHz. So if your HSE has a different value you have to redefine it else the systemCoreClock frequency is not correct which could explain your issue with serial as it probably impact baudrate.
Re: STM32F411VE HardwareSerial sends garbage
There is no F411VE variant defined. So, I wonder which variant you used?
You should check the pins you used and if the default Serial is not mapped on the same one.
meold
Post by meold »
Yes, you are right - by default there is no variant for F411VE available, but it is actually exists in variant files via path "variants\STM32F4xx\F411V(C-E)T", so I've added it according to the tutorial.
I'm not sure how correctly check to which pins mapped default Serial, but anyway it used for USB CDC communication.
Anyway, here is my part for pins config related to uarts:
#ifdef HAL_UART_MODULE_ENABLED
WEAK const PinMap PinMap_UART_TX[] = {
  {PA_2,  USART2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART2)},
  {PA_9,  USART1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART1)},
  {PA_11, USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
  {PA_15, USART1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART1)},
  {PB_6,  USART1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART1)},
  {PC_6,  USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
  {PD_5,  USART2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART2)},
  {NC,    NP,     0}
WEAK const PinMap PinMap_UART_RX[] = {
  {PA_3,  USART2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART2)},
  {PA_10, USART1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART1)},
  {PA_12, USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
  {PB_3,  USART1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART1)},
  {PB_7,  USART1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART1)},
  {PC_7,  USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
  {PD_6,  USART2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF7_USART2)},
  {NC,    NP,     0}
And here is the clock config:
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  __HAL_RCC_PWR_CLK_ENABLE();
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_LSE;
  RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  RCC_OscInitStruct.PLL.PLLM = 6;
  RCC_OscInitStruct.PLL.PLLN = 96;
  RCC_OscInitStruct.PLL.PLLQ = 4;
    Error_Handler();
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
    Error_Handler();
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
  PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
    Error_Handler();
meold
Post by meold »
Yes, you are right - my crystal have 12MHz frequency and I missed this. :roll:
The fix is pretty simple - just by adding to the boards.txt for appropriate board/variant next config:
xxx.build.extra_flags=-DHSE_VALUE=12000000
Thank you for your help :)
Welcome. You can also change it using build_opt.h feature.
https://github.com/stm32duino/wiki/wiki ... uild_opt.h
meold wrote: Wed Feb 22, 2023 5:22 pm
No worry. It is not easy. This is an advanced configuration. Sometimes I forgot this too.
bekean
Post by bekean »
If your HSE is different, you must modify it else the systemCoreClock frequency is incorrect, which may be the cause of your serial communication problems since it likely affects baudrate.
jesse99
Post by jesse99 »
bevis0405 wrote: Tue Jul 25, 2023 2:33 am If you are using interrupts for the UART, make sure that the interrupt handlers are correctly implemented to prevent data loss or corruption.
I am not using interrupts for the UART, this method is not worth trying.
