NUCLEO-H7A3ZI-Q Code loads but does not run
gbgb
Post by gbgb »
I am trying to use a NUCLEO-H7A3ZI-Q board with the Arduino IDE.
Since this specific board is not supported I am using the "Generic H7A3VIHx" board.
I am trying the simplest BLINK sketch using PB0 for the onboard led.
Everything looks fine - builds the code, attaches to the on board ST-LINK and identifies it correctly as well as the target chip, but at the end nothing runs.
Furthermore, after the upload the chip goes into its "locked" state and the programming again is not possible unless you "unlock" (shorting pins 5-7 on CN11).
The hardware is OK as everything works fine when programming C/HAL in the STM32CubeIDE environment.
Any advice?
Re: NUCLEO-H7A3ZI-Q Code loads but does not run
VI is not ZI-Q.
Moreover some config can be required for specific board, ex LDO, SMPS...
jack1211
Post by jack1211 »
Check power (LDO/SMPS) and board-specific settings for the NUCLEO-H7A3ZI-Q, as they differ from the VI board.
gbgb
Post by gbgb »
Thanks.
What is the source of the drop down list for the available generic cards?
I looked where (I believe is) the configuration files:
AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.9.0\variants\STM32H7xx
And I see more folders for 7A than there are in the list. Actualy I see a folder H7A3Z(G-I)TxQ_H7B3ZITxQ but there is no 7A3Z in the drop down list.
It is not added.
You can add them following this wiki:
byquip
Post by byquip »
I have same board to work with and I tried to add it myself using the guide fpiSTM mentioned.
The problem is that H7A3ZITxQ did not appear in the list of Board part number after I add 3 boards from H7A3Z(G-I)TxQ_H7B3ZITxQ/boards_entry.txt to boards.txt.
I possibly missed something but I dont see why they didn't appear.
This is a know issue of Arduino IDE 2, you have to clean the cache:
https://github.com/arduino/arduino-ide/ ... 1152005617
byquip
Post by byquip »
Thank you for the hint.
Removing arduino-ide folder from AppData helps BUT after all the changes and before close IDE need to remove link from Preferences
https://raw.githubusercontent.com/stm32 ... index.json
If not then all changes will be overwritten.
Normally not while you don't reinstall the package.
byquip
Post by byquip »
It happened automatically in my case.
Now I have similar problem as the author.
Upload the blink sketch and nothing happens.
Before that I had some problem in generic_clock.c with unknown PWR_DIRECT_SMPS_SUPPLY.
fixed with:
#define PWR_CR3_SMPSEN_Pos             (2U)
#define PWR_CR3_SMPSEN_Msk             (0x1UL << PWR_CR3_SMPSEN_Pos)
#define PWR_CR3_SMPSEN                 PWR_CR3_SMPSEN_Msk
#define PWR_DIRECT_SMPS_SUPPLY         PWR_CR3_SMPSEN
Any idea why nothing happen?
Log:
Sketch uses 18112 bytes (0%) of program storage space. Maximum is 2097152 bytes.
Global variables use 1360 bytes (0%) of dynamic memory, leaving 1456816 bytes for local variables. Maximum is 1458176 bytes.
Selected interface: swd
STM32CubeProgrammer v2.17.0
ST-LINK SN : 0038004D3532510E31333430
ST-LINK FW : V3J15M7
Board : NUCLEO-H7A3ZI-Q
Voltage : 3.29V
SWD freq : 8000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x480
Revision ID : Rev X
Device name : STM32H7A/B
Flash size : 2 MBytes
Device type : MCU
Device CPU : Cortex-M7
BL Version : 0x92
Memory Programming ...
File : Blink.ino.bin
Address : 0x08000000
Erasing internal memory sectors [0 2]
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:00.098
RUNNING Program ...
Address: : 0x8000000
Application is running, Please Hold on...
