Some General Info - New user
Docara
Post by Docara »
Hello everyone, just joined!
Just a little background-
I am currently trying to design and choose a MCU's for a narrow boat project in the UK, trouble is I really struggle with programming. I can just about deal with the annoying ArduinoIDE and C is driving me nuts trying to learn it. Therefore, I will have to use a package which holds my hands and does 'stuff' for me - currently I use Flowcode for my PIC and AVR projects which fulfils my requirements (up till now).
I do not require massive computing power but low power, and good interrupt options, Touch and Comms.
I came across a Youtube post concerning the BluePills and they seem to fit my needs perfectly, with the exception of having CANBus. However I am concerned about the fakes etc of these devices.
I would like some general advice on STM32's, programming infrastructure / toolchain. The STM site is very confusing, spread out and hard to get concise information.
So
What is the situation concerning using the Arduino IDE as a development platform - there seems to be a number out there what's the difference? Dan Brown, Rogers (here) STMduino.
If haven't downloaded CUBE MX yet how does it compare with, say, Atmel Studio. Can it import libraries / Arduino libraries etc
Would using the ArduinoIDE for development impact on the functionality of theses devices. I am assuming faster clocks and bigger Mems offset things massively.
I read here that there seems to be a multitude of Bootloader options going on with them being made a by STM then code being copied over during bootup (or something) please explain.
The only reason I mention ArduinoIDE is that I have limited experience of it and it does seem to be the easiest to begin with whilst staring out any other options would be gratefully received
thanks
Matt
Re: Some General Info - New user
it is difficult to say whether the stm32duino or the typical arduino or even a barebone avr is the right thing for you if your issues are with programming. the beauty of something like the arduino is that it gets a beginner up and running quickly. you can think of it as the BASIC of mcu programming.
personally I find the arduino ide difficult to navigate, hard to work on a typical project -> a typical project for me often involves 10 or 20 or so files as i re-use my code extensively.
the stm32duino offers considerably more power / features than the arduino but it is also considerably more complex. you also don't have the benefit of a debugger...
if your interest is in embedded programming, i would invest in a simpler but more challenging C environment.
if your interest is in getting something going, i would learn a little bit on the arduino ide while exploring other options -> I use slime text myself.
Arduino IDE is great if you do not want to dig deep into the build process.
I usually use free editors to edit code (ex. Notepad++) and then use Arduino IDE (with the option "Use external editor") just to build the app, or use Eclipse (Sloeber) as a complete development environment.
Docara wrote: Wed Aug 05, 2020 2:06 pm ...
Matt,
Before moving forward with Blue Pill, you really should document what about ArduinoIDE is driving you crazy; is it "C" syntax or the "IDE". If you have successfully worked on PIC & AVR chips, so, ARM is just another microcontroller technology.
Flowcode gives you the "C", so the transition from visual to C should be an easy transition... just a paradigm shift.
ArduinoIDE is deceptively simple: most novice programmers go wrong because their introduction is via YouTube and that fries their brains with useless methodology. Rather, one simply needs to envision a program in Arduino as a 5-step process:
1. Identify required libraries you will utilize,
2. Declare global variables to share
3. Put initialization(s) in the setup() area between braces { }
4. Put user defined requirements and function calls in loop() section between { }
5. Write functions in a logical manner and put them in IDE tabs logically grouped
Engine Monitor.jpg (45.73 KiB) Viewed 5912 times
Section #1
#include "./AnalogAverage.h"        // Matrix summations
#include "./BATTERY.h"              // Voltage and Current
#include "./THERMOCOUPLE.h"         // Exhaust Gas temps left and right
#include "./ENGINE.h"               // Coolent temp, Front cyl temp, Rear cyl temp, oil temp, oil pressure
#include "./FUEL.h"                   // Fuel tank level
Section #2
// Type Variable Declarations for the main sketch tab
float temp        =  0.00;
Section #3
  // analogReference(EXTERNAL) ;    // A precision 5.00 Volt source OR other precision source
  analogReference(DEFAULT) ;
  Serial.println() ;
  // pins defined in THERMOCOUPLE.h
  pinMode(addr_0, OUTPUT); pinMode(addr_1, OUTPUT); pinMode(addr_2, OUTPUT); pinMode(addr_3, OUTPUT);
  digitalWrite(addr_0, LOW); digitalWrite(addr_1, LOW); digitalWrite(addr_2, LOW); digitalWrite(addr_3, LOW);
  delay(50);
Section #4
    analog_0();           // A0  Water temperature
    analog_1();           // A1  Oil temperature
    analog_2();           // A2  Oil Pressure
    analog_10();          // A10 Amps measured
    analog_12();          // A12 Battery voltage measured
    analog_15();          // A15 Fuel pressure
    thermo_0();           //     Exhaust Gas left
    thermo_1();           // To be determined   ... un-comment function in JSON tab
    thermo_2();           // To be determined
    thermo_3();           // To be determined
    thermo_4();           // To be determined
    thermo_5();           // To be determined
    thermo_6();           // To be determined
    thermo_7();           // To be determined
    thermo_8();           // To be determined
    thermo_9();           // To be determined
    thermo_10();          // To be determined
    thermo_11();          // To be determined
    delay(5000);
/*  thermo_12();           // To be determined
    thermo_13();           // To be determined
    thermo_14();           // To be determined
    thermo_15();           // To be determined
Section #5 Now, we write matching code for functions in the tabs, grouping if we desire. Because I often publish my silly little projects, I choose to "encapsulate" libraries within my code to make it easier for readers to get a project downloaded and working.
Example Tab: JSON
/* Faux JSON file format https://groups.google.com/forum/#!topic/node-red/pvY36rlRUdI */
void analog_0(void) {
  float temp = EngineCoolantTemp();
  Serial.print("{\"H2O_Tmp\":"); Serial.print(temp);  Serial.print (",");
void analog_1(void) {                                   /* Oil temperature */
  float temp  = float(EngOilTemp() );
  Serial.print ("\"Oil_Tmp\":"); Serial.print(temp);  Serial.print(",");
  return;
void analog_2(void) {                                   /* Engine Oil Pressure */
  float temp = float (EngineOilPres());
  Serial.print("\"Oil_Prs\":"); Serial.print(temp);  Serial.print(",");
  return;
void analog_10(void) {                                  /* Amps measured */
  float temp = float (BatteryAmps());
  Serial.print("\"Current\":"); Serial.print(temp);  Serial.print(",");
  return;
void analog_12(void) {                                   /* Battery voltage measured */
  float temp = float (BatteryVoltage());
  Serial.print("\"Voltage\":"); Serial.print(temp);  Serial.print(",");
  return;
void analog_15(void) {                                   /* Gasoline fuel pressure */
  float temp = fuelPressure();                                        /* fuel pressure is a fp math function */
  Serial.print("\"Gas_Prs\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_0(void) {                                  /* Exhaust Gas left */
  int temp  = float (thermocouple_channel( 0));
  Serial.print("\"EGT_1\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_1(void) {
  int temp  = float (thermocouple_channel( 1));
  Serial.print("\"EGT_2\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_2(void) {
  int temp  = float (thermocouple_channel( 2));
  Serial.print("\"EGT_3\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_3(void) {
  int temp  = float (thermocouple_channel( 3));
  Serial.print("\"EGT_4\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_4(void) {
  int temp  = float (thermocouple_channel( 4));
  Serial.print("\"EGT_5\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_5(void) {
  int temp  = float (thermocouple_channel( 5));
  Serial.print("\"EGT_6\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_6(void) {
  int temp  = float (thermocouple_channel( 6));
  Serial.print("\"EGT_7\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_7(void) {
  int temp  = float (thermocouple_channel( 7));
  Serial.print("\"EGT_8\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_8(void) {
  int temp  = float (thermocouple_channel( 8));
  Serial.print("\"EGT_9\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_9(void) {
  int temp  = float (thermocouple_channel( 9));
  Serial.print("\"EGT_10\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_10(void) {
  int temp  = float (thermocouple_channel(10));
  Serial.print("\"EGT_11\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_11(void) {
  int temp  = float (thermocouple_channel(11));
  Serial.print("\"EGT_12\":"); Serial.print(temp);  Serial.print("}\n");
  return;
//    ***** NOTE:  YOU MUST UNCOMMENT IN THE MAIN TAB THE CALLING ROUTINE AND UNCOMMENT+EDIT TO PROVIDE NODERED WITH A NEW LABEL *****
/*void thermo_12(void) {
  float temp  = float (thermocouple_channel(12));
  Serial.print("\"EGT_13\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_13(void) {
  float temp  = float (thermocouple_channel(13));
  Serial.print("\"EGT_14\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_14(void) {
  float temp  = float (thermocouple_channel(14));
  Serial.print("\"EGT_15\":"); Serial.print(temp);  Serial.print(",");
  return;
void thermo_15(void) {
  float temp  = float (thermocouple_channel(15));
  Serial.print("\"EGT_16\":"); Serial.print(temp);  Serial.print(",");
  return;
Example Tab: THERMOCOUPLE.h
#include "./MAX31855.h"              // Local (embedded) library
int thermoDO    = 51;                // SPI Data Out
int thermoCS_1  = 52;                // first EGT thermocouple amp Chip Select
int thermoCLK   = 53;                // common SPI clock to both 31855s
int thermoCS_2  = 50;                // second EGT thermocouple amp Chip Select used in Europa design
int8_t addr_0   = 36;               // 2^0    Addressline 0 going to analog mux
int8_t addr_1   = 34;               // 2^1    Addressline 1 going to analog mux
int8_t addr_2   = 32;               // 2^2    Addressline 2 going to analog mux
int8_t addr_3   = 30;               // 2^3    Addressline 3 going to analog mux
/* CONCEPT
 *  A single MAX31855 chip will be used in conjunction (front-ended) by a 16 channel analog switch. channel_address_ 0-3 will be set HIGH/LOW
 *  to represent 0 through 15 address.  Then, after settling delay(?) the thermocouple object will be called similarily to below.  Address will
 *  be incremented, allowed to settle, and the thermocouple object called again.  These calls must take place from within tab JSON and a small
 *  function created so it can be called from the main program loop on tab: Engine_Monitor_1.  Each JSON function must print a unique identifier
 *  so that the downstream CodeRed program can select the tag, convert to a numeric and assign a label.
MAX31855 thermocouple_(thermoCLK, thermoCS_2, thermoDO);
// ________________________________________________________________________SPI bus #1
float thermocouple_channel( int mux_address) {
    switch(mux_address) {
      case 0:
        break;
      case 1:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, LOW); digitalWrite(addr_2, LOW); digitalWrite(addr_3, LOW);
        break;
      case 2:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, LOW); digitalWrite(addr_3, LOW);
        break;
      case 3:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, LOW); digitalWrite(addr_3, LOW);
        break;
      case 4:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, LOW); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, LOW);
        break;
      case 5:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, LOW); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, LOW);
        break;
      case 6:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, LOW);
        break;
      case 7:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, LOW);
        break;
      case 8:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, LOW); digitalWrite(addr_2, LOW); digitalWrite(addr_3, HIGH);
        break;
      case 9:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, LOW); digitalWrite(addr_2, LOW); digitalWrite(addr_3, HIGH);
        break;
      case 10:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, LOW); digitalWrite(addr_3, HIGH);
        break;
      case 11:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, LOW); digitalWrite(addr_3, HIGH);
        break;
      case 12:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, LOW); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, HIGH);
        break;
      case 13:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, LOW); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, HIGH);
        break;
      case 14:
        digitalWrite(addr_0, LOW); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, HIGH);
        break;
      case 15:
        digitalWrite(addr_0, HIGH); digitalWrite(addr_1, HIGH); digitalWrite(addr_2, HIGH); digitalWrite(addr_3, HIGH);
        break;
     delay(75);
     float temp = 0.00;
     double c = thermocouple_.readCelsius();
     if (isnan(c)) {
      // error code here
     } else {
      temp = thermocouple_.readInternal() ;
      temp = thermocouple_.readFarenheit() ;
     return (temp) ;
List of files with extensions:
Arduino handles the ".h/.cpp" and ".ino" differently: ".ino" files are concatenated to the main_sketch".ino" before feeding to the preprocessor. This is done to facilitate automatic function prototyping.
Good luck,
https://www.hackster.io/rayburne/projects
