OK, I decided that I should put the codes used up here and while knocking the grammar into shape I decided to move the Nano pulses a bit further apart….
It looks as if the ‘Early’ pulses were actually very late ones. Oops sorry.
Blue Pill running slow
Re: Blue Pill running slow
- DRFDWF V2.png (72.67 KiB) Viewed 2463 times
And here is the code:
From GonzoG
Asm version 1
Asm 2 version 2
From GonzoG
// From https://www.stm32duino.com/viewtopic.php?f=7&t=704&p=4659#p4659 GonzoG IO_speed_test.zip
#define dWF(a,b) digitalWriteFast(digitalPinToPinName(a),b)
#define dRF(a) digitalReadFast(digitalPinToPinName(a))
// Modified to use PB3 for read and PB4 for write
#define PIN3r PB3
#define PIN4w PB4
pinMode(PIN3r,INPUT);
pinMode(PIN4w,OUTPUT);
while ( dRF(PIN3r)){ dWF(PIN4w,1); dWF(PIN4w,0);}
pinMode(PB4,OUTPUT);
pinMode(PB3,INPUT);
asm (
" ldr.w r0, = #0x40010C08 \n" // GPIOB_IDR (0x40010C00 + 0x08)) Input Data Register
" ldr r2, = #0x40010C10 \n" // GPIOB_BSRR (0x40010C00 + 0x10))Bit Set Reset Register
" ldr r3, = #0x10 \n" // Bit 4 = 0b0001 0000
" ldr r4, = #0x100000 \n" // Bit 4 = 0b0001 0000 but shifted 16bits higher into
// Bit 4 = 0b0001 0000 upper (reset) register. See BSRR p173.
"aloop: \n"
" ldr r1, [r0] \n" // Load contents of IDR to r1
" ands r1, r1, #0x08 \n" // AND with Set flags against Bit 3 = 0b0000 1000
" beq aloop \n" // Branch if equal to zero (ie, no pulse there)
" str r3, [r2] \n" // Set port high
" str r4, [r2] \n" // Set port low
); // Use C loop() for repeat
pinMode(PB3,INPUT);
asm (
"aloop: \n"
" cbz r1, nopulse \n" // CBZ (branch zero) seems better but must branch forwards
"nopulse: \n" // CBZ landing point
" b aloop \n" // Repeat
