[SOLVED] BluePill I2C Wire.setClock(400000) Stops USB working
Jimbo13
Post by Jimbo13 »
On my BluePill programme, using I2C , when I include the line "Wire.setClock(400000);" the USB port, which was working before, Stops working.
The I2C was working before as well.
I have "wire version=1.0" installed.
Any suggestions please.
Re: BluePill I2C Wire.setClock(400000) Stops USB working
Seems obvious as there is no link btw them.
Could you share you sketch?
And also provide all options sets in the Arduino menu, please.
Jimbo13
Post by Jimbo13 »
I am using Visual Micro.
Annotation 2020-04-01 112459.jpg (43.42 KiB) Viewed 8483 times
Even setting "Wire.setClock(100000);" stops USB and I get a windows message "USB Device not recognised etc", and the LED does not blink.
The programme seems to compiles and uploads OK.
As you can see I have remmed out most things.
//thanks to JoopBrokking http://www.brokking.net/imu.html
#include <LiquidCrystal_I2C.h>          //johnrickman/LiquidCrystal_I2C
//Declaring global variables
int gyro_x, gyro_y, gyro_z;
long acc_x, acc_y, acc_z, acc_total_vector;
int temperature;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
long loop_timer;
int lcd_loop_counter;
float angle_pitch, angle_roll, angle_yaw;
int angle_pitch_buffer, angle_roll_buffer, angle_yaw_buffer;
//boolean set_gyro_angles;
float angle_roll_acc, angle_pitch_acc, angle_yaw_acc;
float angle_pitch_output, angle_roll_output, angle_yaw_output;
LiquidCrystal_I2C lcd(0x27, 16, 4);//Initialize the LCD library
    pinMode(PC13, OUTPUT);// Set up the built-in LED pin as an output:
   // Serial.begin(9600);//not needed
   // Wire.setClock(100000);
    Wire.begin();
    delay(250);
    //setup_mpu_6050_registers();
// the loop function runs over and over again until power down or reset
    digitalWrite(PC13, !digitalRead(PC13));
    delay(500); //change each build as programme check
    Serial.println("Hello Jimmy");
    read_mpu_6050_data();
    Serial.print("X = ");
    Serial.println(gyro_x);
    Serial.print("Y = ");
    Serial.println(gyro_y);
    Serial.print("Z = ");
    Serial.println(gyro_z);
    delay(250);
void read_mpu_6050_data() {                                             //Subroutine for reading the raw gyro and accelerometer data
    Wire.beginTransmission(0x68);                                        //Start communicating with the MPU-6050
    Wire.write(0x3B);                                                    //Send the requested starting register
    Wire.endTransmission();                                              //End the transmission
    Wire.requestFrom(0x68, 14);                                           //Request 14 bytes from the MPU-6050
    while (Wire.available() < 14);                                        //Wait until all the bytes are received
    acc_x = Wire.read() << 8 | Wire.read();                                  //Add the low and high byte to the acc_x variable
    acc_y = Wire.read() << 8 | Wire.read();                                  //Add the low and high byte to the acc_y variable
    acc_z = Wire.read() << 8 | Wire.read();                                  //Add the low and high byte to the acc_z variable
    temperature = Wire.read() << 8 | Wire.read();                            //Add the low and high byte to the temperature variable
    gyro_x = Wire.read() << 8 | Wire.read();                                 //Add the low and high byte to the gyro_x variable
    gyro_y = Wire.read() << 8 | Wire.read();                                 //Add the low and high byte to the gyro_y variable
    gyro_z = Wire.read() << 8 | Wire.read();                                 //Add the low and high byte to the gyro_z variable
void setup_mpu_6050_registers() {
    //Activate the MPU-6050
    Wire.write(0x6B);                                                    //Send the requested starting register
    Wire.write(0x00);                                                    //Set the requested starting register
    //Configure the accelerometer (+/-8g)
    Wire.write(0x1C);                                                    //Send the requested starting register
    Wire.write(0x10);                                                    //Set the requested starting register
    //Configure the gyro (500dps full scale)
    Wire.write(0x1B);                                                    //Send the requested starting register
    Wire.write(0x08);                                                    //Set the requested starting register
Try the setClock after the WireBegin
Jimbo13
Post by Jimbo13 »
OK , thanks that worked.
I followed this video which states that the Setclock() should be called before the wire.begin otherwise the I2c will run at the default speed.
Look at 4 minutes 30.
https://www.youtube.com/watch?v=ImctYI8hgq4
I also did do a lot of searching to find an example which included the Setclock but could not find anything. I aslo tried to see what was happening in the library but it got too complicated.
Jim
Re: [SOLVED] BluePill I2C Wire.setClock(400000) Stops USB working
In our implementation setClock assume the Wire is initialized.
https://www.arduino.cc/en/Reference/WireSetClock
Even the API is not clear. It only specify "modifies".
Re: [SOLVED}BluePill I2C Wire.setClock(400000) Stops USB working
About the video, it uses Roger's core not the STM32 core.
Jimbo13
Post by Jimbo13 »
And in the Arduino link:
There is no mention that Wire should be initialized before setClock.
I just noticed that a long way down in the comments for the video somebody does mention that with the new STM32 the setClock must go after Wire.begin(), where did they get that information from or was it just by experimenting?
Its an uphill struggle to do anything in STM32 as there seems not to be much information for the beginner.
